Add Dreamhost support to LetsEncrypt addon
The LetsEncrypt add-on supports numerous DNS providers for the DNS challenge. Dreamhost isn’t supported, but I believe Dreamhost does support DNS challenge (Traefik uses it). Is it possible to add Dreamhost DNS challenge support to the add-on?
I’ve used Dreamhost for ACME DNS validation in Proxmox.
Here’s Dreamhost’s DNS API and the ACME Dreamhost info.
Any chance you’d be willing to provide a sample/example?
I’ve been able to generate an API key and change the ACME server, but I’m not quite sure how to use DNS validation outside of the list of providers that Let’s Encrypt currently supports.
Thanks!
I’d be very grateful if you could share the process, I’m in contact with Dreamhost support and so far they’re not helpful.
