Add Edisio Device (working with the ENKI app)
Hello to all. I just started to configure my home assistant. Having originally a small budget, I found myself with many different brands. I finally see the end of it and the last elements to connect are my connected plugs of the brand EDISIO, which worked via the application ENKI. I couldn’t find anything on third party applications, nor on the internet to add my devices. Do you have any ideas?
Thanks in advance !
I also have an Enki box and an Edisio plug.
I added a Raspberry Pi to run Home Assistant and interface differents brands (RS485, inverter, EnOcean).
I command Enki box by simulating an EnOcean control switch.
So, from an automation, I can drive my Edisio plug.
But often, I loose the link because Enki stop to communicate with the plug :frowning:
Hello
Can you explain to me in detail how you simulate with an Enocean command ? Have you bought any more equipment ?
In my that I have evology modules to control my shutters on the box envy
Hi Nicok,
sorry for the delay
I use a Raspberry Pi 4 with an EnOcean key, USB 300
My Python software see the key as a serial COM.
Software use the ENOCEAN SERIAL PROTOCOL
Hello, I have an ENKI ceiling lamp. home assistant does not support ENKI, and I could not find an application that would work with it. can anyone help?
