Hi folks,
had a bigger problem last week as my water heater for the tub in the garden made itself and turned on at 0:00 with no external trigger. The problem was that not only did the sun not shine at night and therefore it was not really heated with the remaining solar power, but also that I had no temperature control in it that switched off the shelly as soon as one of the two sensors was over 80 degrees C. The boiler withstood the 120 degrees … not the garden hoses!
So yesterday I had a large steam boiler in the garden, which wasn’t planned
I would like to expand my automation to the point, or create a second one, that ensures that the Shellys only switch when
sun.sun
is activated and
sensor.hotwater_temperature_tank_middle
or
sensor.hotwater_temperature_tank_out
does not measure over 80 degrees C.
Unfortunately I can’t do it alone. Just too many loops and conditions… Thanks for your help.
Here is the previous automation:
alias: Steuerung PV WarmWasser
description: Nutzen der PV-Überschussleistung durch selektives Schalten von Verbrauchern
- platform: state
entity_id:
- binary_sensor.solar_uberschuss_stufe_0
attribute: position
to: below
for:
hours: 0
minutes: 0
seconds: 10
- platform: state
entity_id:
- binary_sensor.solar_uberschuss_stufe_1
attribute: position
to: in_range
for:
hours: 0
minutes: 0
seconds: 5
- platform: state
entity_id:
- binary_sensor.solar_uberschuss_stufe_2
attribute: position
for:
hours: 0
minutes: 0
seconds: 5
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: switch.turn_off
data: {}
entity_id:
- switch.warmwasser_solar_garten_switch_0
- switch.warmwasser_solar_garten_switch_1
- conditions:
sequence:
- service: switch.turn_on
data: {}
entity_id:
data: {}
entity_id:
- conditions:
sequence:
data: {}
entity_id:
data: {}
entity_id:
mode: single
thx for help !
meanwhile I use a old analog Timerscoket to disable the shelly at night … what a shame …
