Add Eve Energy to HA (without external OTBR) failed
Adding Eve Energy (thread Version) to HA is not working. OTBR is setup and running fine. Using an external OTBR like Apple TV works fine, too. I can add Eve energy in HA
But I don´t need the Apple TV anymore.
Here is the log of HA OTBR
otbr-agent[172]: 00:22:14.658 [W] Platform------: failed to send ICMPv6 message: Cannot assign requested address
otbr-agent[172]: 00:22:14.660 [W] RoutingManager: Failed to send RA on infra netif 2: Failed
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::8aa1:1cd1:49e5:78f6/end0/2
otbr-agent[172]: 00:22:14.962 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:22:14.962 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:22:15.308 [W] Platform------: failed to send ICMPv6 message: Cannot assign requested address
otbr-agent[172]: 00:22:15.308 [C] RoutingManager: RsSender: Failed to send RS 1/3: Failed
otbr-agent[172]: 00:22:16.846 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:22:16.846 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:22:31.353 [W] Platform------: [netif] ADD [U] fd7e:a445:86f8:6671:0:ff:fe00:fc11 failed (InvalidArgs)
otbr-agent[172]: 00:22:31.353 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:47:48.640 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:47:48.641 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:47:52.475 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:47:52.476 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:02.669 [W] Platform------: [netif] ADD [U] fd7e:a445:86f8:6671:0:ff:fe00:fc11 failed (InvalidArgs)
otbr-agent[172]: 00:48:02.669 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:08.085 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:48:08.085 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:11.167 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:48:11.167 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:22.940 [W] Platform------: [netif] ADD [U] fd7e:a445:86f8:6671:0:ff:fe00:fc11 failed (InvalidArgs)
otbr-agent[172]: 00:48:22.941 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:35.736 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:48:35.737 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:38.722 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 00:48:38.722 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 00:48:50.880 [W] Platform------: [netif] ADD [U] fd7e:a445:86f8:6671:0:ff:fe00:fc11 failed (InvalidArgs)
otbr-agent[172]: 00:48:50.880 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 01:15:55.867 [W] Platform------: failed to send ICMPv6 message: Cannot assign requested address
otbr-agent[172]: 01:15:55.869 [W] RoutingManager: Failed to send RA on infra netif 2: Failed
otbr-agent[172]: 01:15:55.943 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 01:15:55.943 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 01:15:56.184 [W] Platform------: failed to send ICMPv6 message: Cannot assign requested address
otbr-agent[172]: 01:15:56.184 [C] RoutingManager: RsSender: Failed to send RS 1/3: Failed
otbr-agent[172]: 01:15:58.184 [W] Platform------: [netif] ADD [U] fd02:bbc6:9fea:1:7323:c251:a2ec:6cd9 failed (InvalidArgs)
otbr-agent[172]: 01:15:58.185 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
otbr-agent[172]: 01:16:12.836 [W] Platform------: [netif] ADD [U] fd7e:a445:86f8:6671:0:ff:fe00:fc11 failed (InvalidArgs)
otbr-agent[172]: 01:16:12.836 [W] Platform------: [netif] Failed to process event, error:InvalidArgs
Seems to me an IPV6 issue. But I have IPV6 setting on automatic and some IPv6 addresses are shown in the network adapter (fdca:xxxxxxxxx and fe80:xxxxxxx)
I read using IPV6 automate is not enough for thread it must be a static setting.
But I struggle with the IPV6 static settings especially what to add in the gateway and dns field.
Changed to static, the two ipv6 addresses are shown in the network adapter section.
On my router I have disabled ipv6.
Anybody can help ?
Perhaps that’s your problem? Have you tried turning it on, at least on the LAN?
I tried this, too
But regarding that post it is not necessary to have ipv6 enabled in your router…
That depends. If your “router” (which in consumer terms usually means an all-in-one access point, switch, gateway, DHCP server, DNS forwarder and router) is on the LAN route between your devices and is blocking IPv6, bad things can happen.
Issue is known.
