Add feature inside ViCare Integration: heating.dhw.pumps.circulation.schedule
I’m currently use the Viessmann ViCare integration. Id like to start the DHW circulation pump without any scheduler, just when i need.
I’m able to call the command by the Viessman API using postman. heating.dhw.pumps.circulation.schedule/commands/setSchedule,
using one schedule “empty” when i want to power off, and a second schedule “always on” when i want to start the pump.
Is it possible to integrate this function inside the integration?
Sharing the commands you use may help the author and the community in the meantime.
Be sure to mask any secrets.
Thanks for the suggestion.
I’ve uploaded the screenshot of the configuration used in postman to send the command. The idea is to associate the command to a button when i want to start the circulation pump and another button to stop the circulation pump.
sorry for my bad english :-(…
I’m new in Home Assistant…it would be use full to have this feature, I’d like to have posibility to start/stop DHW circulation pump without any scheduler, just when i need it.
I have Viessmann vitodens 200-w gas boiler.
Is it possible to integrate this function inside the integration please ?
thanks
I would love to have that function either. Seems that turning off the DHW is not making any savings because water still circulates and gets colder and colder. I would love to use automation to turn it on and off. Is there a chance you can add it to integration?
I would like it too - or the ability to set the DHW pump schedule.
I would like it too.
Thank you
