Energy entities sometimes report 0 during init. This leads to huge outliers on the energy dashboard. Is it possible to add a filter to pre-existing entities using yaml customize?
I do have the problem that my Solax integration (as well as some shelly) do report 0 for some energy entities. This leads to huge outliers in the energy dashboard. I usualy fix these outliers using the developer tools and fix the statistic values. However, this happens now more often and it is quite anoying of fixing this all the time.
Since this is a custom integration, I was hoping that I can add an outlier filter to the entity using yaml. Customize.
Something along like this:
homeassistant:
customize:
sensor.battery_input_total:
device_class: "energy"
state_class: total
filter: outlier
window_size: 4
Is this possible?
I know how to add another entity based on this as an input entity. However, if I exchange the input entity on the energy dashboard I loose all the previous recorded history. Which I really do not want to loose.
Thank you
