Add Forward Slash to Input
I’m trying to take an !input number for time_pattern and add a forward slash to it for a trigger. For instance, if the !input is set to 10, I want to make a time_pattern of “/10” instead.
I’ve been playing with various syntax for longer than I care to admit and can’t seem to figure it out. Is this possible? I couldn’t seem to get the variable to work, but the “!input detection_frequency” seems to work. Just can’t get it to add a / in front of it. Thanks in advance!
  input:
    detection_frequency:
      name: Detection Frequency
      description: The detection algorithm will run in every defined seconds
      default: 5
      selector:
        number:
          min: 1.0
          max: 60.0
          mode: box
          unit_of_measurement: seconds
          step: 1.0
variables:
  DETECTION_FREQUENCY_VAR: !input detection_frequency
mode: single
max_exceeded: silent
triggers:
- trigger: time_pattern
  seconds: "/"!input detection_frequency
Hello thegame3202,
You need to template the entire field there, so the selector has to be a text selector ( or maybe a select selector ) and the user has to enter /10 or whatever.
At least that is my experience.
Hmm, explains why it wasn’t working haha. Thank you!!
If one of the suggestions listed solves your problem, please consider clicking the solution button to close the thread. (even your own…)
