https://www.homematic-ip.com/produkte/detail/homematic-ip-wandtaster-6-fach.html
I can see that the HmIP-WRC6 is already documented in the latest REST-API Version:
So I hope the Homematic IP Component will be updated soon
Not sure who is the right contact for the component Mattias Welponer (mxworm) or Pascal Vizeli (pvizeli)
Mattias Welponer (mxworm) Created the Hass.io Homematic IP component. Maybe you can contact him and ask for un update for hass.io. Otherwise you need to wait.
I also bought the 6-fold button, but I only get a binary sensor “Empty Battery” under developer tools.
Can someone help me? The wall thermostat works perfectly.
Many thanks
Stephan
have a look at the documentation:
BR
Thank You very much, I found it! Now it works.
@Stephan4711, @SukramJ , Is WRC6 working not only as a battery sensor? The document link from @SukramJ says WRC6 and other push buttons are not yet supported, I am wondering how you make it work? I am trying to use HmIP-WRC2 but it only shows as a battery sensor now.
Hi Hochul,
Sorry.
I’ve only seen the question now.
Only the battery sensor is displayed as an entity.
But the 6 or 2 buttons can be used in the automation. You have to select event as the trigger, the event type is homematic.keypress. Event dates:
channel: 1 (button)
name: (14 character name)
param: PRESS_SHORT or PRESS_LONG
In Homematic you have to create an empty program, see appendix.
Greetings
Stephan
