Tasmota supports color command using [x,y] coordinates or HueSat command
I am unable to use the default schema or json schema as being a zigbee light, there are no individual topics for hs, xy, rgb, brightness etc, this needs to be done via templating a JSON ZbSend command.
Merged, it will be included in the next release. Once released, hs_command_topic and xy_command_topic options will be available for mqtt lights using the basic schema.
While testing, I could get a Tradfri light connected to my zbbridge work with a config something along these lines.
Note: this config assumes that the light has been named with something like ZbName 0x1234,My_Light.
# This config requires the following options to be set on the Tasmota zbbridge:
# ZbDeviceTopic 1
# ZbNameTopic 1
# ZbOmitDevice 1
name: "My Color Zigbee Light"
unique_id: "123456789abc-1"
command_topic: "cmnd/my-zbbridge/ZbSend"
on_command_type: first
# NOTE: this MUST EXACTLY MATCH state_value_template below
payload_on: '{ "Device": "My_Light", "Send": {"Power": 1} }'
payload_off: '{ "Device": "My_Light", "Send": {"Power": 0} }'
state_topic: "tele/my-zbbridge/My_Light/SENSOR"
# This is ugly. Since HA compares the template output with payload_*,
# this template must generate the expected payload_on or payload_off.
# Unfortunately, the basic schema has no command_template option (yet :-) ).
state_value_template: >-
{%- set dev = "My_Light" -%}
{%- set zb = value_json.ZbReceived | default(value_json.ZbInfo) | default({}) -%}
{%- if zb.Power is defined -%}
{ "Device": "{{ dev }}", "Send": {"Power": {{ zb.Power }}} }
{%- endif -%}
brightness_scale: 254
brightness_command_topic: "cmnd/my-zbbridge/ZbSend"
brightness_command_template: '{ "Device": "My_Light", "Send": {"Dimmer": {{ value }} } }'
brightness_state_topic: "tele/my-zbbridge/My_Light/SENSOR"
brightness_value_template: >-
{{ zb.Dimmer | default }}
xy_command_topic: "cmnd/my-zbbridge/ZbSend"
xy_state_topic: "tele/my-zbbridge/My_Light/SENSOR"
xy_command_template: '{ "Device": "My_Light", "Send": {"Color": "{{ [(x * 65536) | round | int, 65534] | min }},{{ [(y * 65536) | round | int, 65534] | min }}"} }'
xy_value_template: >-
{%- if zb.X is defined and zb.Y is defined -%}
{{ zb.X / 65536 }},{{ zb.Y / 65536 }}
{%- endif -%}
min_mireds: 250
max_mireds: 454
color_temp_command_topic: "cmnd/my-zbbridge/ZbSend"
color_temp_command_template: '{ "Device": "My_Light", "Send": {"CT": {{value}}} }'
color_temp_state_topic: "tele/my-zbbridge/My_Light/SENSOR"
color_temp_value_template: >-
{{ zb.CT | default }}
# Tasmota/HA: 0/hs, 1/xy, 2/color_temp
color_mode_state_topic: "tele/my-zbbridge/My_Light/SENSOR"
color_mode_value_template: >-
{%- if zb.ColorMode is defined -%}
{%- set modemap = {0: "hs", 1: "xy", 2: "color_temp"} -%}
{{ modemap[zb.ColorMode] | default }}
{%- endif -%}
