Add Intergas InComfort Lan2RF gateway Version2
As the users grow and also community. I have a question.
Also I`m new to Home Assistant. I think its a great tool and hope to learn much more of it.
The possibilities are endless. Just use the creative mind and you can accomplish anything.
I own a Intergas station with a Lan2RF module. And now I`m looking to integrate this information.
My new home assistant is running on a Ubuntu (Virtual server) version 18.04.3 LTS.
The version of Home assistant is 0.100.3. And I understand that Lan2RF is integrated in HA.
I folowed this manual.
Later I understand that you need to install the InConfort-Client. So I installed the client.
In the configuration.yaml I have the following:
incomfort:
  host: IP_ADDRESS
  username: USERNAME
  password: PASSWORD
In the notification shows a message:
 Invalid config
 The following components and platforms could not be set up:
 * [incomfort](https://home-assistant.io/integrations/incomfort/)
 Please check your config.
Is there someone that can help me, pushing in the right direction.
Thank you in advance
Greetings
Palermo
Hi, Did you get this fixed - if not, could you raise an issue here and I can take look at it.
