When you want to connect to HomeAssistant via IPv6 from the internet, your router must be able to forward the request to HomeAssistant.
This is not working, when IPv6 privacy extensions are enabled.
Please add an option in the network settings, to change this behaviour:
[ipv6]
addr-gen-mode=eui64
Yes, that feature is really needed. I’m fighting with addr-gen-mode since hours!
When I think about it. Home Assistant is a server system and the default ipv6.addr-gen-mode for servers should be eui64. Maybe we don’t need a UI extension and it should be default anyway.
I didn’t get it to work using a USB drive and gave up. Disabled IPv6 completely.
You can change the default settings with:
- ssh on Port 22222 (see Dev SSH) or
- The SSH & Web Terminal Addon or
- with Monitor and Keyboard directly connected to the hardware and run
loginin the ha-cli
The modify:
vi /etc/NetworkManger/system-connections/
or use nmcli
nmcli c s
# Check that default is used. If not adapt the following command
nmcli c edit Home\ Assistant\ OS\ default
In nmcli run:
set ipv6.addr-gen-mode eui64
safe
If nmcli c s show an second configuration edit this one to.
After these steps. The privacy extension is disabled, but if you use the UI Network settings again, the changes will be overwritten.
Thanks for your suggestion, but there is no network manager available in my ha-cli.
nmcli is not installed and the path /etc/NetworkManger is not existing.
I am using homeassistant OS on a Raspi:
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
IPv4 addresses for eth0: 192.168.253.20/24
IPv6 addresses for eth0: 2001:a61:11f9:5901:99dd:xxx/64, fd52:4759:bd4b:4fd0:xxx/64, fe80::d32d:b573:9a1f:xxx/64
IPv4 addresses for wlan0:
OS Version: Home Assistant OS 7.0
Home Assistant Core: 2021.12.4
Home Assistant URL: http://hassio.local:443
Observer URL: http://hassio.local:4357
[core-ssh ~]$ nmcli
-bash: nmcli: command not found
You need to get OUT of the ha cli, you can run the ha login command, or ssh directly to your supervisor.
For others it may help the exact commands once in the CLI are:
save
quit
This is a solution that works with or without eui64.
I had the issue that using Homeassitant (Home Assistant Operating system on Raspberry Pi 4) behind a Fritzbox and DSLite (only real IPv6 adress) the port forward (e.g. for wireguard VPN) was not working - or only working for a certain time.
Issue was the “IPv6 Interface-ID” (the right side part of the Ipv6 adress of the homeassitant server) that was used by Fritzbox did not match the real IP.
I found out that “privacy extensions” are the reason of that. As soon as these are disabled in homeassistant - the server gets the same IPv6 adress as expected by the Fritzbox (without PE the right part is calculated from MAC address - thats how the fritzbox needs it)
Anyway, disabling the PE as described in this thread - is really a bit tricky. The simplest solutionfor me was really to take the “HA raspi” connect HDMI Monitor and USB Keyboard and execute “login” command. THIS DOES NOT WORK WITH THE ADD-ON CLI - only when directly connected!.
Then use vi command as mentioned in post from trunneml (dec 21). But the location on my side was a bit different… ```
I did cd /etc/NetworkManger/system-connections/ and inside there I could find a file to edit with “vi ” (sorry forgot the exact name) … inside the file is a section with [ipv6] that I just changed to:
[ipv6]
addr-gen-mode=eui64
Then “ESC”
x
To store the changes
(on german keyboard “:” is “ö” or SHIFTö if I remeber correct…
I hope this helps someone in same situation.
Anyway having this as a configuration option e.g. in “System/Network” would be much easier.
best regards!
Columbo
I am also facing this issue. For a server privacy extension makes zero sense and IMO should be disabled by default, or at least be easily configurable in the GUI.
I was using the above mentionen method (EUI64) for years with IPv6. Have there been changes to home assistant regarding this?
/etc/NetworkManager/system-connections/default
contains the correct “addr-gen-mode=eui64” entry.
2: enp0s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 06:60:3c:4c:86:8d brd ff:ff:ff:ff:ff:ff
inet 192.168.207.172/24 brd 192.168.207.255 scope global dynamic noprefixroute enp0s18
valid_lft 863876sec preferred_lft 863876sec
inet6 2003:c3:XXXX:XXXX:9a52:d360:60aa:e58e/64 scope global dynamic noprefixroute
valid_lft 7079sec preferred_lft 1450sec
inet6 fdf6:58be:ea00:16fa:949:e0e2:4688:d2c9/64 scope global dynamic noprefixroute
valid_lft 7079sec preferred_lft 3479sec
inet6 fe80::fc4b:b12b:c90b:3734/64 scope link noprefixroute
valid_lft forever preferred_lft forever
Note that the MAC-Address does not show up in the fe80 part of the IPv6 address.
I could fix this by typing ha network update end0 --ipv6-method auto --ipv6-privacy disabled --ipv6-addr-gen-mode eui64 into the Terminal. Afterwards I needed to ajust the IPv6-Interface-ID to have it in sync.
