Hi, I just started with HA (running supervised) and struggling with the following :
I would like to add label to states options on a device (created via Tuya).
The lovelace and the states are as follow :
You can’t easily alter the entity created by an integration, but you can create a Template select entity that can act as a proxy so that you can use whatever option names you prefer.
Thank you for pointing to the right solution, it’s working as intended.
If someone is looking to do the same, I’ve added the following code to configuration.yaml :
