When working with the HA OS via terminal, the less
command is missing.
The thing is, journalctl
uses less
by default to provide pagination/searching/etc. So without less
being installed, you end up printing out more logging than you can look at - and no simple way to search with context, etc.
Look I know I can filter using journalctl directly, or pipe in to grep, but less
should just be included
You forgot to vote for your own request
FYI, the PR has been merged into dev
