When I go to the entity I get:
This entity (“light.kitchen_lights”) does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail.
The issue is as you’ve already posted, though entities now can be added to areas they are required to have a unique id thus being added to the entity registry.
The light.group documentation (Light Group - Home Assistant) has a unique_id option, but this does not appear to work (I get a configuration error claiming “Invalid config for [light.group]: [unique_id] is an invalid option for [light.group]”).
unique_id string (optional)
An ID that uniquely identifies this light group. If two lights have the same unique ID, Home Assistant will raise an error.
Frustrating! Is this a bug (or is the doco out of date)?
