In the newly cascaded configuration menu, if many tabs are open to different areas, all have the same name. i.e. congi/server/logs in open, but tab displays “configuration - home assistant”. config/automation/debug is open and tab displays “configuration - home assistant”. When lots of tabs are open, no visibility to what each tab is.
