Aurora ABB PowerOne Solar PV integration, shows only 4 entity instead it could show many more like, for example, the same custom integration but Modbus TCP.
My inverter, Aurora 6kW outdoor - N/A - Transformerless Version - PV Version (-3G03-) _C.0.3.4, might show
string power 1
string tension 2
current string 2
string power 2
string tension 3
current string 3
string power 3
string tension 4
string current 4
string power 4
inverter mains voltage 1
inverter grid current 1
inverter network power 1
inverter mains voltage 2
inverter mains current 2
inverter network power 2
inverter mains voltage 3
inverter mains current 3
inverter network power 3
inverter frequency
inverter effectiveness
inverter temperature
temp. boot inverter
prod. total inverter 1
R.iso.
iLeak
peak production of the day
peak production maximum.
I know the inverter is an old model, but for developers, is it possible to implement it?
R.iso.
iLeak
string power 1
string tension 1
string current 1
string power 2
string tension 2
string current 2
I am adding them from page 9 of this specification document, but I don’t see string power 1 or string power 2. Do you know what they relate to on this list?
Hello Dave, is the integration work completed or do you want to add more sensors?
If you feel like it, you could add peak production of the day and peak production maximum…
Hi, i got now all 6. inverters added to the plugin. I can only see 2 sensors: current PV and total energy. How to add the sensors for the strings or do i need to add them through the inverter. thanks
