Add motion eye os to hass installation
Hi I tried to execute following script
clear
echo “Starting Motioneye Installation”
sleep 1
clear
cd /home/pi
sudo wget https://github.com/ccrisan/motioneye/wiki/precompiled/ffmpeg_3.1.1-1_armhf.deb
sudo dpkg -i ffmpeg_3.1.1-1_armhf.deb
sudo rm -rf ffmpeg_3.1.1-1_armhf.deb
sudo apt-get remove libavcodec-extra-56 libavformat56 libavresample2 libavutil54
sudo apt-get install libavutil54 libavformat56 libswscale3 -y
sudo apt-get install python-pip python-dev curl libssl-dev libcurl4-openssl-dev libjpeg-dev libx264-142 libavcodec56 libavformat56 libmysqlclient18 libswscale3 libpq5 v4l-utils -y
sudo wget https://github.com/Motion-Project/motion/releases/download/release-4.0.1/pi_jessie_motion_4.0.1-1_armhf.deb
sudo dpkg -i pi_jessie_motion_4.0.1-1_armhf.deb
sudo rm -rf pi_jessie_motion_4.0.1-1_armhf.deb
sudo pip install motioneye
sudo mkdir -p /etc/motioneye
sudo cp /usr/local/share/motioneye/extra/motioneye.conf.sample /etc/motioneye/motioneye.conf
sudo mkdir -p /var/lib/motioneye
sudo cp /usr/local/share/motioneye/extra/motioneye.systemd-unit-local /etc/systemd/system/motioneye.service
sudo systemctl daemon-reload
sudo systemctl enable motioneye
sudo systemctl start motioneye
however i get errors
Processing triggers for systemd (215-17+deb8u6) …
Processing triggers for man-db (2.7.0.2-5) …
Collecting motioneye
_ Downloading motioneye-0.35.2.tar.gz (757kB)_
_ 100% |████████████████████████████████| 757kB 177kB/s_
Could not import setuptools which is required to install from a source distribution.
_ File “/usr/local/lib/python3.4/dist-packages/pip/req/req_install.py”, line 387, in setup_py_
_ import setuptools # noqa_
_ File “/usr/local/lib/python3.4/dist-packages/setuptools/init.py”, line 12, in _
_ import setuptools.version_
_ File “/usr/local/lib/python3.4/dist-packages/setuptools/version.py”, line 1, in _
_ import pkg_resources_
_ File “/usr/local/lib/python3.4/dist-packages/pkg_resources/init.py”, line 70, in _
_ import packaging.version_
ImportError: No module named ‘packaging’
cp: cannot stat ‘/usr/local/share/motioneye/extra/motioneye.conf.sample’: No such file or directory
cp: cannot stat ‘/usr/local/share/motioneye/extra/motioneye.systemd-unit-local’: No such file or directory
Failed to execute operation: No such file or directory
Failed to start motioneye.service: Unit motioneye.service failed to load: No such file or directory.
pi@hassbian:/ $
I wanted to install this on hassbian pi image to have both on 1 pi. Any suggestions?
I recommend using the image i also have this. U can later add some curl commands for binary sensors in hass
