The current integration does not support the MyAir3 system which uses an older tablet than the current supported systems, here are a list of working commands to control the older system (still relies on having a static ip on the controller):
#Authenticate
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/login\?password\=password | xmllint --xpath "/iZS10.3/authenticated/text()" -
#Get System Data
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/getSystemData | xmllint --format -
Example:
<?xml version="1.0" encoding="UTF-8"?>
<iZS10.3>
<request>getSystemData</request>
<mac>0004a38f3a1a</mac>
<authenticated>1</authenticated>
<system>
<type>12</type>
<name>HOME</name>
<MyAppRev>7.4</MyAppRev>
<zoneStationHasUnitControl>1</zoneStationHasUnitControl>
<dhcp>1</dhcp>
<ip>192.168.10.20</ip>
<netmask>255.255.255.0</netmask>
<gateway>192.168.10.1</gateway>
<unitcontrol>
<airconOnOff>1</airconOnOff>
<fanSpeed>2</fanSpeed>
<mode>3</mode>
<unitControlTempsSetting>0</unitControlTempsSetting>
<centralActualTemp>25.6</centralActualTemp>
<centralDesiredTemp>23.0</centralDesiredTemp>
<airConErrorCode> </airConErrorCode>
<activationCodeStatus>0</activationCodeStatus>
<numberOfZones>7</numberOfZones>
<maxUserTemp>32.0</maxUserTemp>
<minUserTemp>16.0</minUserTemp>
<availableSchedules>8</availableSchedules>
</unitcontrol>
<zs103TechSettings>
<numberofConstantZones>1</numberofConstantZones>
<zsConstantZone1>1</zsConstantZone1>
<zsConstantZone2>0</zsConstantZone2>
<zsConstantZone3>0</zsConstantZone3>
<tempSensorSelect>0</tempSensorSelect>
<returnAirOffset>0.0</returnAirOffset>
<controlZoneNumber>0</controlZoneNumber>
<newAirFitted>0</newAirFitted>
<ACinfo>1</ACinfo>
<systemID>16</systemID>
</zs103TechSettings>
</system>
</iZS10.3>
#Get Specific Zone by Number
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/getZoneData?zone=1 | xmllint --format -
Example:
<iZS10.3>
<request>getZoneData</request>
<zone1>
<name>KITCHEN</name>
<setting>0</setting>
<userPercentSetting>100</userPercentSetting>
<maxDamper>100</maxDamper>
<minDamper>0</minDamper>
<userPercentAvail>1</userPercentAvail>
<actualTemp>0.0</actualTemp>
<desiredTemp>24.0</desiredTemp>
<RFstrength>0</RFstrength>
<hasLowBatt>0</hasLowBatt>
<hasMotorError>0</hasMotorError>
<hasClimateControl>0</hasClimateControl>
</zone1>
</iZS10.3>
#On
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?airconOnOff=1 | xmllint --xpath "/iZS10.3/ack/text()" -
#Off
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?airconOnOff=0 | xmllint --xpath "/iZS10.3/ack/text()" -
fan Speed LOW
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?fanSpeed=1 | xmllint --xpath "/iZS10.3/ack/text()" -
fan Speed MED
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?fanSpeed=2 | xmllint --xpath "/iZS10.3/ack/text()" -
fan Speed HIGH
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?fanSpeed=3 | xmllint --xpath "/iZS10.3/ack/text()" -
#Mode COOL
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?mode=1 | xmllint --xpath "/iZS10.3/ack/text()" -
#Mode HEAT
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?mode=2 | xmllint --xpath "/iZS10.3/ack/text()" -
#Mode FAN
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?mode=3 | xmllint --xpath "/iZS10.3/ack/text()" -
#Temperature for HEAT / COOL
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setSystemData?centralDesiredTemp=24.0 | xmllint --xpath "/iZS10.3/ack/text()" -
#Enable Zone 1
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setZoneData?zone=1&zoneSetting=1 | xmllint --xpath "/iZS10.3/ack/text()" -
#Disable Zone 1
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setZoneData?zone=1&zoneSetting=0 | xmllint --xpath "/iZS10.3/ack/text()" -
#Enable Zone 1 and set Percentage to 50%
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setZoneData?zone=1&zoneSetting=1&userPercentSetting=50 | xmllint --xpath "/iZS10.3/ack/text()" -
#Disable Zone 1 and set Percentage to 50%
curl -s -m 20 -H "Accept: application/xml" -X GET http://192.168.10.20/setZoneData?zone=1&zoneSetting=0&userPercentSetting=50 | xmllint --xpath "/iZS10.3/ack/text()" -
#Set Timer (clock time to stop, e.g. if it’s 10pm and you want to stop in 1 hour and ```
30 minutes, set endTimeHours to 23 and endTimeMinutes to 30
curl -s -m 20 -H “Accept: application/xml” -X GET http://192.168.10.20/setZoneTimer?startTimeHours=0&startTimeMinutes=0&endTimeHours=23&endTimeMinutes=30&scheduleStatus=2 | xmllint --xpath “/iZS10.3/ack/text()” -
#Clear Timer
curl -s -m 20 -H “Accept: application/xml” -X GET http://192.168.10.20/setZoneTimer?startTimeHours=0&startTimeMinutes=0&endTimeHours=0&endTimeMinutes=0&scheduleStatus=0 | xmllint --xpath “/iZS10.3/ack/text()” -
Discussions on this can be found on:
https://community.home-assistant.io/t/advantage-air-myair3-integration/498700
