Till now I used the add-on “Samba Backup” to take my daily backups of home assistant.
This is the configuration :
Now I want to add a network storage, but this seems not working :
But I get an error :
What am I missing ?
What am I missing ?
2 things are missing here:
compatibility_mode, you are not showing that option.Sorry, didn’t see that one (is indeed activated) :
There seems nothing in the logs of the Synology.
I must say it’s an old Synology, so…
https://www.home-assistant.io/common-tasks/os/#network-storage-configuration
3 For the
CIFSoption, only version 2.1+ is supported.
So yeah, as you use that option you are probably running version 1 or 2.
OK, so I must stay with the add-on (not a problem, works fine).
Thanks !
