Add "Next triggered" column to default Automations UI
Hi, please consider the following feature for the “Automations” screen:
By default the Automations screen only shows one column: “Last triggered”. It would be useful to have another column called “Next trigger” that shows the time/date when the automation will be trigger next. This is very useful if you have a lot of timed dependant automations that trigger on specitic times with offsets and also relative times like sunrise/sunset/dusk/dawn,etc.
For example, I can have 15 automation rules that depend on different conditions like sunrise/sunset, specific time plus some offset, etc. It would be great to see all of those “calculated” times on one single screen.
Thank you.
Duplicate of https://community.home-assistant.io/t/proposal-next-trigger-attribute-for-automations/353980
