Hi
I have few switchs in node-red but i don’t know how can i add them in home assisstant.
if someone know that.
they are my switchs
and i want add them like that to home assisstant
Hi
they are my switchs
Hello Vahid_Barz,
I see in your flow that you use MQTT, you could use an MQTT switch, see here:
https://www.home-assistant.io/components/switch.mqtt/
Or what is very interesting, ESPHome, look here in the link:
https://esphome.io/index.html
greetings
i use this code but it doesn’t work !!!
is it something wrong?
- platform: mqtt
command_topic: "lctech/cmd"
payload_on: "relay,0,1"
payload_off: "relay,0,0"
Hello, I am not a professional, in your configuration, everything seems to be fine. (Is “switch:” about?) If you stick to the description, there should be no problems. The correct formatting is very important !!! Did you check your configuration and restart your system?
yeah that is switch. i check it and restart raspberry again but it doesn’t work…
i don’t know why
thanks i find problem that was /
- platform: mqtt
command_topic: "/lctech/cmd"
Just out of interest, if you have control over the MQTT topic, best practice is not to start with a “/”. See here for example.
