I couldn’t find the observer url at that time, So I just decided to unplug the power and power it up again.
No I know it’s port 4357, but probably I will forget this soon.
is it possible to add the observer url to the message?
then I would be able to check some more.
The observer is only available on installations with a supervisor.
When you do not get past this screen, it does not know if you have a supervisor or not.
On top of that the observer only works from inside your LAN.
I don’t see a way how this can be added in a proper manner.
I think it can be available from the outside as long as you forward the port.
but I think it would also have value if it only works from inside the LAN.
Maybe some client JS can be created to check if the port is accessible from the current location.
