First stab at making an add-on using the new base image (homeassistant/armhf-base:latest), in the dockerfile when it hits “RUN apk add --no-cache git” it returns an error code: 1. If I do it with wget, it works fine. I’ve looked at the alpine package list and “git” is there.
Error:
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 421, in start
resp = yield from self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 303, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.6/site-packages/hassio/api/util.py", line 30, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/lib/python3.6/site-packages/hassio/api/addons.py", line 98, in install
self.addons.install(addon, version), loop=self.loop)
File "/usr/lib/python3.6/site-packages/hassio/addons/__init__.py", line 128, in install
if not await addon_docker.install(version):
File "/usr/lib/python3.6/site-packages/hassio/dock/__init__.py", line 55, in install
return await self.loop.run_in_executor(None, self._install, tag)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 130, in _install
return self._build(tag)
File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 173, in _build
path=str(build_dir), tag=build_tag, pull=True)
File "/usr/lib/python3.6/site-packages/docker/models/images.py", line 172, in build
raise BuildError(chunk['error'])
docker.errors.BuildError: The command '/bin/sh -c apk add --no-cache git' returned a non-zero code: 1
Dockerfile:
ENV LANG C.UTF-8
# Setup base
CMD [ "/run.sh" ]
