2023-04-23T04:09:36Z WRN The user running cloudflared process has a GID (group ID) that is not within ping_group_range. You might need to add that user to a group within that range, or instead update the range to encompass a group the user is already in by modifying /proc/sys/net/ipv4/ping_group_range. Otherwise cloudflared will not be able to ping this network error=“Group ID 0 is not between ping group 1 to 0”
2023-04-23T04:09:36Z WRN ICMP proxy feature is disabled error=“cannot create ICMPv4 proxy: Group ID 0 is not between ping group 1 to 0 nor ICMPv6 proxy: socket: protocol not supported”
2023-04-23T04:09:36Z INF Starting metrics server on [::]:36500/metrics
2023/04/23 05:09:37 failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See UDP Receive Buffer Size · quic-go/quic-go Wiki · GitHub for details.
2023-04-23T04:09:37Z INF Registered tunnel connection connIndex=0 connection=2844c9c7-f03b-4d2a-9be5-c36c06bbee02 event=0 ip=198.41.192.167 location=LHR protocol=quic
2023-04-23T04:09:37Z INF Registered tunnel connection connIndex=1 connection=a66c49db-a6a7-46e0-bbd7-42cf9efab2e7 event=0 ip=198.41.200.63 location=MAN protocol=quic
2023-04-23T04:09:39Z INF Registered tunnel connection connIndex=2 connection=39d4691d-0e14-43f3-a394-2c8dc9dc748f event=0 ip=198.41.200.43 location=MAN protocol=quic
2023-04-23T04:09:40Z INF Registered tunnel connection connIndex=3 connection=76fe89e1-fd63-481c-90dd-9775588a7684 event=0 ip=198.41.192.107 location=LHR protocol=quic
2023-04-23T08:26:10Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b8569cbddd83-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:10Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:11Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b85fbcf87599-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:11Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:13Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b86d1f5375c6-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:13Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:17Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b880792f23f3-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:17Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:21Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b89a184a24b7-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:21Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:26Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b8ba2a33dd23-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:26Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:31Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b8da5ebc88a3-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:31Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:36Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b8fa9d797320-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:36Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=3 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.107 type=ws
2023-04-23T08:26:41Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b91a7969dd4c-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:41Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:46Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b93afd7d23c3-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:46Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:52Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b95b9cdf76d1-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:52Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:26:57Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b97cdd7b4139-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:26:57Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:02Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b99edf1648c9-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:02Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:08Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b9c0a81f48b5-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:08Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:15Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4b9edadc57545-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:15Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:22Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4ba16dda04133-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:22Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:31Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4ba50ee8d7478-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:31Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:40Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4ba89dcda88a7-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:40Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
2023-04-23T08:27:49Z ERR error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” cfRay=7bc4babf7b0723c3-LHR event=1 ingressRule=0 originService=http://homeassistant:8123
2023-04-23T08:27:49Z ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused” connIndex=0 dest=https://stallardhome.cc/api/websocket event=0 ip=198.41.192.167 type=ws
I just started getting the same issue in my logs. Everything appears to be working normally though.
