Add-on/docker container does not get an IPv6 address (Home Assistant Yellow)
Maybe I am missing out on something general because I haven’t fully understood the relation between add-ons and the docker container run by the supervisor but I am stuck with the following:
I am running Home Assistant Yellow (core 2024.5.1; sv: 2024.04.4; os: 12.2) in a mixed IPv4/IPv6 network. Network adaptor end0 is provided with both address types automatically (and correctly).
I now noticed that an add-on fails to get its own IPv6 address. I figured this out by using the “advanced ssh & web terminal” add-on to take a look at the running docker containers.
So I am assuming (which might be totally bogus) something went wrong, when the supervisor started the container. Provided there is a least some sense to it: is there a way to control the supervisor’s behavior or would this have to be done in the add-on’s YAML file exclusively?
Thanks a lot in advance!
Zack
What AddOn is it?
Ah, sorry, I’m not familiar with that AddOn.
There is an ongoing discussion about this: RFC: Support IPv6 for network isolated add-ons · Issue #2133 · home-assistant/supervisor · GitHub
Thanks a lot!
