Add-ON ESPHOME can not install
Good morning, I`m new at this ( sorry ) , but i am so much confused about how can i install the add-on of the ESPHOME in the Home Assistant.
I have seen so much videos that explain that and it seems so simple ( just go to the add-on store and search for ESPHOME and install it ) but doing that i can not find ( even search in the search box ) the ESP.
Any help will be much apreciated
Thank you Tom_I.
I follow that but in my home assistant i can not find the ESPHOME add-on. and its is up to date 2022.6.6.
Thanks in advance.
Did you do this bit?
I’m guessing you skipped step 1.
  1. Add the repository
  2. Add the addon
I have tried but,…
How can i have the official ESPHome add-on repository ??
Sorry once more but i`m very new to this.
You litterally have to click the button it tels you to on the web page.
when i click the button this is what appens
and when i
and when i click the open link
this is the mesage i received from chrome
Go to the addon-store in home assistant. Click the three dots icon top right of the page and add this repository:
https://github.com/esphome/esphome-home-assistant-addon
You should then see the addon in the store.
unfourtunatly it does`nt sole the issue :frowning: as you can see in the image.
That was my fault sorry. Should be:
https://github.com/esphome/home-assistant-addon
Done :slight_smile: finally it works :slight_smile:
Thank you for the support.
wish you all the best.
