Those listed as Beladeleistung (negativ) oder Ladeleistung (positiv)
in your output. Each phase is also available right below that. Unless I misinterpret the sensor name
Hello forum members,
I would like to rename an entity and also change the unit. Of course, the value must also be adjusted to the new unit. How do I do this?
Example:
Renaming is easy:
_sum/ConsumptionActiveEnergy → Self-consumption kWh
_sum/ConsumptionActiveEnergy;;;;;Self-consumption kWh
But how do I adjust the values? _sum/ConsumptionActiveEnergy is in Wh and should be displayed as kWh
1500Wh → 1.5kWh
You can use the value template in the overwrites to do the conversion, here is an example how I use it:
sensor_overwrite:
- channel;device_class;state_class;device_unit;value_template;name
battery0/Tower0PackVoltage;voltage;measurement;V;{{value | int /
10}};Live-FEMS: battery0/Tower0PackVoltage
ctrlGridOptimizedCharge0/TargetEpochSeconds;timestamp;measurement;;{{value |
int(0) | as_datetime()}};Live-FEMS:
Or you could just use a template sensor, which can be configured easily in Home-Assistant UI as a helper nowadays.
Could you please explain this to me in more detail, preferably using my values as an example, I’m still a complete beginner.
Got it, thank you thank you thank you
Here is a finished example, works wonderfully:
- _sum/ConsumptionActiveEnergy;;;kWh;{{ (value | int / 1000) | round (2) }};Eigenverbrauch Energie
One more question, how can I find out which channels there are? Is there a command that returns all available channels? If so, where do I have to enter it?
Oh, it’s a Primus system with Kaco Hybrid TL3 from Energy-Depot, based on OpenEMS and works quite well with the Fems plugin.
You can use a request like this one:
curl -s http://x:[email protected]:80/rest/channel/.*/.* -o channel-names.txt
You can also use an API tester as shown in the fenecon docs with the wildcard channel name: FEMS App REST/JSON Lese-/Schreibzugriff :: FENECON Dokumente
Am I doing something wrong here?
“curl http://x:[email protected]:80/rest/channel/.*/.* -o” C:\channel-names.txt
Hmm first of all, you there is not supposed to be a space between the second star and the dot.
Maybe it works then. If it still doesn’t work, then it might be possible that the REST-API is different or not supported on the non FEMS System
I had already seen and tested the thing with the star and the space (last entries in the command window). Then this query doesn’t seem to work for me. What a pity.
Hmm, you can try it with 8084 for the port instead of 80, maybe the web server there does not forward the rest API.
Unfortunately without success, testet with 8084, 8884, 8883, 1883, 1884
Do you get a 404 on Port 8084 as well or another error?
No, this:
curl: (7) Failed to connect to 192.168.168.138 port 8084 after 2083 ms: Could not connect to server
Ok, could you please send me (maybe privately) a screenshot of the page when you click on the top right corner on the online or offline portal? There should be a list of all the installed components.
Do you mean this:
Zähler
PV DC charger0
KACO blueplanet hybrid 10.0 TL3 DC Charger
hy-switch meter0
KACO blueplanet hybrid 10.0 TL3 Grid Meter
PV AC pv0 (Komponente ist inaktiv!)
KACO blueplanet hybrid 10.0 TL3 PV Inverter
Speichersysteme
Storage ess0
KACO blueplanet hybrid 10.0 TL3 Ess
Externe Schnittstellen
ctrlApiWebsocket0
Controller Api Websocket
Cloud-Schnittstellen
ctrlBackend0
Controller Api Backend
ctrlBackend1
Geräte-Schnittstellen
kacoCore0
KACO blueplanet hybrid 10.0 TL3 Core
Standard-Komponenten
ctrlDebugLog0
Controller Debug Log
rrd4j0
Timedata RRD4J
scheduler0
Scheduler All Alphabetically
Weitere
Core.AppManager _appManager
Core App-Manager
Core.ComponentManager _componentManager
Core Component-Manager
Core.Cycle _cycle
Core Cycle
Core.Energy _energy
Core Energy Scheduler
Evcs.SlowPowerIncreaseFilter _evcsSlowPowerIncreaseFilter
EVCS Power
Core.Host _host
Core Host
Kaco Update _kacoUpdate
PRIMUS Update Handler
Core.Meta _meta
Core Meta
Ess.Power _power
ESS Power
Core.PredictorManager _predictorManager
Core Predictor-Manager
Yes, that is what I meant. There actually doesn’t seem to be the REST-API. Can you check if there is maybe an option in the settings to enable it or something like that?
If you can’t find anything, then you could try to view the network analysis in your browser and search for the websocket request after reloading the page. Then you can click it and go to the response tab and find the line with “subscribeChannels”. There you can see all the channels that the Web UI requests.
