There are docker images with nginx and letsencrypt preconfigured with auto updating of certificate.
Not sure if also includes dynamic DNS updates (e.g. with duckdns)
Happybubbles presence
duckdns is comming in 3minutes
Cant save the “Options” data.
Goes back to default data when save is clicked.
"token": "db8b2324-5ff6-4d07-8930-xxxxxxxxxxxx",
"domains": ["xxxxxxxx.duckdns.org"],
"seconds": 300
is fix now
What about HDMI CEC?
I have finished the local-addon-version of the HASS Configurator. If someone is willing to test and maybe suggest some changes, here’s the current repository: https://github.com/danielperna84/hassio-hass-configurator
Edit:
There now is a real add-on repository at https://github.com/danielperna84/hassio-addons
Starting with Hass.IO 0.26 this can be added as a repository and installed with a few clicks.
Smartthings MQTT Bridge would be a great addition. It only requires Node and Mosquitto (which is already available on HassIO).
FTP server, since some IP cameras can upload images to FTP.
I have moved the add-on configuration discussion to it’s own topic at
UniFi controller would be nice for this
The Concord232 component can’t run without the concord232 server so that would be a nice add-on.
I would add to the list Homebridge
Homebridge would be really nice
I would like to se
https://community.home-assistant.io/t/floorplan-for-home-assistant/17394
As a addon.
sense Hat would be handy
Apache server to make available contents of a specific folder would be useful e.g to enable browser based browsing of images captured by a camera
We already support the local www folder in the home Assistant config dir
I wasn’t aware of that but found the blog post now https://home-assistant.io/blog/2016/04/07/static-website/ Didn’t find any detail in the docs?
