Add-on not showing as green in dashboard despite being started
My Mosquittobroker add-on doesn’t seem to start, it’s not turning green. However, in the list of available add-on items, it is shown as green, But the MQTT broker service is not working despite being configured properly.
What does the log of that add on say after you try to start it?
It’s completely empty even after refresh.
If you start the add on it’s log should populate as it starts.
It’s just blank.
What about the hassio log then. Seems like it isn’t actually starting.
Might be worth it to uninstall reinstall and double check your config.
It turned out to be a conflicting port issue: Home Assistant Community Add-on: MQTT Server & Web client
