Add-On Security Calculation
I wanted to know how Add-On Security Rating worked. Documentation is sparse on the topic so here’s the current values
All Add-ons start with a base security rating of 5. You can increase or decrease this number via methods listed below.
add +2 to security rating
ingress: true (overrides auth_api rating below)
add +1 to security rating
auth_api: true
apparmor.txt present in addon
add -1 to security rating
apparmor: false (overrides apparmor.txt presence)
privilege: contains one or more of [NET_ADMIN, SYS_ADMIN, SYS_RAWIO, SYS_PTRACE, SYS_MODULE, or DAC_READ_SEARCH] (applies only once)
hassio_role: manager (overrides admin below)
host_network:true
add -2 to security rating
hassio_role: admin
host_pid: true
full_access:true
Automatic rating of 1
docker_api: true
Finally, the score is limited to a range of +1 to +6. If you’ve managed to go lower than 0 or higher than 6 your score will be constrained to a value between 1 and 6.
Source: https://github.com/home-assistant/supervisor/blob/8d8587ca29bd32594af0ec2649486d205ef0dfab/supervisor/addons/utils.py#L28
How to arbitrarily add security:
  1. Declare ingress:true in the config.json and add this line into your run.sh
fun() {  while true; do nc -l -p 8099 -e  echo -e 'HTTP/1.1 200 OK\r\nServer: DeskPiPro\r\nDate:$(date)\r\nContent-Type: text/html; charset=UTF8\r\nCache-Control: no-store, no cache, must-revalidate\r\n\r\n<!DOCTYPE html><html><body><p>For some reason this improves security rating for Home Assistant, so I am using it.</body></html>\r\n\n\n'; done }; fun&
This is what you will see on the web interface
  1. create an apparmor.txt file by declaring “/path/to/resource.ext rwix,” or “/path/to/folder** rwix”
Theoretically, one could request full_access:true, apply these items above, and still attain a rating of 6.
