What is the path the the add-on configurations uses? I can not for the life of me get ssl working on anything within hass except for the main system. I have my own cert I want to use and no add-ons can find it…
I’ve tried both absolute paths and relative (to what?)
Edit:
So I disabled SSL in the add-on (I’m using the community mqtt/hivemq if it makes a difference)
I connected to the docker and looked at its file system…
root@a0d7b954-mqtt:/share/ssl$ ls
ca.pem cert.pem dhparams.pem fullchain.pem key.pem
Awesome… I found the files… Lets set this up…
"log_level": "info",
"certfile": "/share/ssl/cert.pem",
"keyfile": "/share/ssl/key.pem",
"web": {
"enabled": true,
"ssl": true
"broker": {
"enabled": true,
"enable_ws": false,
"enable_mqtt": false,
"enable_ws_ssl": true,
"enable_mqtt_ssl": true,
"allow_anonymous": false
"mqttusers": [
"username": "none",
"password": "nope",
"readonly": false,
"topics": [
And lets start up mqtt again…
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: MQTT Server & Web client v0.3.0
Mosquitto MQTT Server bundled with Hivemq's web client
By: Franck Nijhof <[email protected]>
armhf / null / HA 0.84.6 / SU 141 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
FATAL: The configured certfile is not found
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
Nope… it cant find my certs…
Edit:
Finally got it work…
So apparently the files HAVE to be located in the /ssl
(from hassio) or /resin-data/ssl/
(from host)
Once I moved those files over everything started to work. I’ll have to update my script now for the changes, but it shouldn’t be too hard.
One more final edit… I just happened to notice in the readme of mqtt that it even says these files must be located there… oh well. That would of saved me several hours of work had I seen that.
