At supervisor is the add-onn store empty, and installed add-ons not visible any more at the add-onn tab?
The installed add-ons are still operational
What to do?`
I installed and old snapshot back. Still the add-on store not vissible and installed add-ons not visible .
EDIT: I don’t know what I did but the installed and standard add-ons are back again.
Before this problem I did have extra standard add-ons. They are still not showing anymore?
How can I add these ones again?
EDIT2: I found them again… pffff
It was: https://addons.community
Somehow my depository was corrupted
And again my addons are not showing up again.
It drives me crazy.
I don’t know the reason for that?
20-03-29 16:20:26 ERROR (MainThread) [supervisor.store.git] Can't clone https://addons.community repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://addons.community /data/addons/git/942cda15
stderr: 'Cloning into '/data/addons/git/942cda15'...
fatal: repository 'https://addons.community/' not found
I try to add a new repository as mentioned in the message above in EDIT2.
Then I do find this error in the supervisor chapter at system.
(Only once, after restart and doing it again it is not showing up anymore)
But it is also not possible to load/ see the standard add-ons?
They are not here??
I do see that the addons directory is empty if I look at Samba?
I do run Supervisor 213
and HA version 106.6
And do see it is not part of a snapshot. So is that probely causing the problem, not coming back after restore a snapshot??
Is it posible to downgrade supervisor version somehow??
EDIT: I know it is the combination of supervisor 213 and HA 0.106.6
After update to 0.107.7 the add-ons are back again
I’ve just noticed that in the latest version of Home Assistant (on HassOS), only the official Add-on store is visible. All of Frenk’s third party addons are no longer shown, nor is the ESPHome repository I had installed.
