I am having the same issue. Installed on a raspberry pi, but no luck searching in the /mnt/data/supervisor folder. I have documented my logs on reddit.
Anyone get it back working ? I am having the same issues @TheStigh was having, where there repository.json can’t be found on the system…
Here is some other finding: The file is apparently deleted automatically after some time. Its being deleted as soon as i hit the reload button on the add-on store page. However, if i reboot the system immediately after creating it, i can open the add on store page for some time. I think its some kind of security system wiping it ?
Edit: I disabled protection mode for esphome. Maybe thats a workaround for me until the update.
After much cursing and head scratching I’m now running 0.93 but the store is still broken. I’ve tried following the many different fixes with wildly different locations but I’ve no idea which is the right fix. My /mnt has nothing in it, my /usr/share is devoid of a hassio directory.
Unlike others I hadn’t touched anything in the store, no new repository added, it just stopped working.
Still getting the same error:
18-06-22 11:12:38 ERROR (MainThread) [hassio.utils.json] Can't read json from /data/addons/git/7bce6681/repository.json: [Errno 2] No such file or directory: '/data/addons/git/7bce6681/repository.json'
18-06-22 11:12:38 WARNING (MainThread) [hassio.store.data] Can't read repository information from /data/addons/git/7bce6681/repository.json
18-06-22 11:12:38 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 62 new - 0 remove
18-06-22 11:12:39 INFO (MainThread) [hassio.addons] Found 6 installed add-ons
18-06-22 11:12:39 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 3.3
18-06-22 11:12:39 INFO (SyncWorker_6) [hassio.docker.interface] Attach to hassioaddons/appdaemon3-armv7 with version v3.0.1
18-06-22 11:12:39 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 5.4
18-06-22 11:12:39 INFO (SyncWorker_9) [hassio.docker.interface] Attach to esphome/esphome-hassio-armhf with version 1.12.2
18-06-22 11:12:39 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/home-panel-armv7 with version v0.4.1
18-06-22 11:12:39 INFO (SyncWorker_11) [hassio.docker.interface] Attach to homeassistant/armv7-addon-letsencrypt with version 3.0
18-06-22 11:12:39 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-06-22 11:12:44 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
As long you wont access the root OS you wont be able to cretae that missing file. If you have a virtual machine or another machine running Linux, you can connect the SD card and add that file manually. If thats not an option, follow this tutorial to enable root SSH access.
esphome added a new repository especially for hassio. So the Core esphome removed the repository.json which than disappeared on our machines and broke them.
Now we need to place that file back, boot the system, remove the old repository and add the new updated one.
That’s fine (Well no it’s not actually, I’m pretty peeved that my system has been done over by someone changing a file or two outside of my system) but where does one get a copy of the missing file from?
Is there likely to be an update that will fix it for those who don’t have the time or experience to fix it manually?
Immediately reboot system. Watch your system until it becomes responsive. Go to your addon page, delete the old esphome repository (delete the repository only, not esphome as you might want to backup that first DO NOT USE THE RELOAD ICON IN THE UPPER RIGHT CORNER. This will remove the repository file immediately.
After removing add the new esphome repository using this URL: https://github.com/esphome/hassio
This way i got the new esphome repo, but i have my old installation still running. After copying all configs i will delete and reinstall esphome.
I too am suffering from this issue and would like to add to the available information. I run a Hassio VM from a NUC with Proxmox. Over time before I made changes, I made clones of the currently working VM. I also maintained a copy of the original bare setup (ver 0.91.1). At all of the prior stages I was able to enter the add-on store since I was adding add-ons. However, today all versions display the ADD-ON Store ‘Failed to fetch add-on’ error message when run separately.
Unless something is being changed in Hassio during the attempt to connect to the add-on store, it appears that the problem rests on the other side.
check the system log in GUI and look for an error message:
“Can’t read json from /data/addons/git/18c35ad6/repository.json” <<< number might be different
I lost my repository.json file also somewhere during a restart.
So, I did exactly what you described. And now it is finally solved, I guess. I restarted the system and the add ons ‘tab’ is still working. What I also noticed is now the number in the path has changed to 15ef4d2f and the file structure looked more like the other directories.
Thank you for your investigations today.
None of this works, I now have the repository.json files in what appears to be two esphome directories and a still broken Add-on store. This is becoming a real PITA
Unfortunately all the fixes I’ve seen on here won’t work for me. I’m running Hassio as a Docker container on CentOS 7. Esphome doesn’t show up anywhere on my system and I have repository.json file in /usr/share/hassio/addons/git/a0d7b954. This is where all the non-core addons reside on my system. I see this in the system log and can’t track down what the error is.
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/hassio/hassio/api/security.py", line 144, in token_validation
File "/usr/src/hassio/hassio/api/utils.py", line 32, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/hassio/hassio/api/addons.py", line 158, in list
ATTR_NAME: repository.name,
File "/usr/src/hassio/hassio/store/repository.py", line 41, in name
return self.data.get(ATTR_NAME, UNKNOWN)
File "/usr/src/hassio/hassio/store/repository.py", line 36, in data
return self.sys_store.data.repositories[self.slug]
KeyError: 'c7a94ee9'
Its not directly an hassio issue. I think they will implement at some point a more robust solution of the gui that is not affected but giving hints what fails.
But until then, i think you must fix it using ssh.
