Entering login: cd… is wrong, you are already logged in as you can see the prompt change.
You are logged in at port 22 to SSH addon which is inside one decker container. Follow the steps from my post above to log in at port 22222 using certificate (not password).
Is fixed automatic with release 164
Follow:
https://developers.home-assistant.io/docs/en/hassio_debugging.html
to get ssh sytem access with “hassio >” prompt. Whenever you see “core-ssh:” you are still inside a docker container and this is not good in this case.
Just follow what pvizeli tell: update your Hass.io supervisor to 164 and this problem is now fixed.
I’m using version 166 (most current at the moment) and the problem continues. I just do not want to update the HA version that is in ‘0.87’.
Is there any correlation between the supervisor version and the H.A. version? Do I need to update both?
I did the procedure and could not get access to the repository as before …
Everything same
