Add-on Store is broken ‘Failed to fetch add-on info’
Getting this error on an installed system that was fine and also on a new test install on a VM, pretty sure it’s not my end as others are reporting this.
Is something broken with the store?
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/hassio/hassio/api/security.py", line 144, in token_validation
  File "/usr/src/hassio/hassio/api/utils.py", line 32, in wrap_api
    answer = await method(api, *args, **kwargs)
  File "/usr/src/hassio/hassio/api/addons.py", line 158, in list
    ATTR_NAME: repository.name,
  File "/usr/src/hassio/hassio/store/repository.py", line 41, in name
    return self.data.get(ATTR_NAME, UNKNOWN)
  File "/usr/src/hassio/hassio/store/repository.py", line 36, in data
    return self.sys_store.data.repositories[self.slug]
KeyError: '7bce6681'
19-05-13 22:19:18 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-05-13 22:19:18 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-05-13 22:19:19 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/OttoWinter/esphomeyaml repository
19-05-13 22:19:19 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/esphome/hassio repository
19-05-13 22:19:22 ERROR (MainThread) [hassio.utils.json] Can't read json from /data/addons/git/7bce6681/repository.json: [Errno 2] No such file or directory: '/data/addons/git/7bce6681/repository.json'
19-05-13 22:19:22 WARNING (MainThread) [hassio.store.data] Can't read repository information from /data/addons/git/7bce6681/repository.json
19-05-13 22:19:22 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 0 new - 0 remove
19-05-13 22:19:22 ERROR (MainThread) [aiohttp.server] Error handling request
    resp = await task
Please search before posting:
Yes Mr Forum Policeman I’d seen that and commented on it but it’s in the configuration forum and it’s clearly a Hass.io issue not a configuration issue so I posted my information here where Hass.io users/support/creators are in my opinion more likely to see it.
If I’ve done wrong I’m sorry and I’ll remove my post.
Not helpful.
Yep exactly what I was saying.
How is my post unhelpful? I’ve given log information in the correct forum!
Your contribution, if it can be called that, is just moaning and complaining.
Actually I politely asked you to search before posting as you were simply duplicating known topics.
You were the one that started with childish passive aggressive insults.
There’s nothing more childish than someone saying “He started it”
