Add-on store is missing on the docker image
I can’t see the add-on store on my home assistant on docker.
Why
The add on store isn’t available in the docker installation
what can i do if i want add-on store?
Use supported method of installation.
You either use an installation method that supports add-ons or you manage your own containerised applications. Most addons are available as applications on Dockerhub. The only thing you lose by doing it this way is that you have to manage updates and configuration yourself.
