Add on store problems
I’ve been using HA for a little while but never really looked under the covers until a problem appeared after an upgrade a few weeks back that says (one message for each add-on installed):
This doesn’t appear to be the only problem… for example it also appears that the ESP Home menu item has disappeared but my ESP config files and running devices seem to be showing up OK.
If i go to the add-on store it just shows one add on that i have already got installed (GivTCP) .
If i look at the HA Core logs only one error shows up for esphome:
Logger: homeassistant.components.esphome.coordinator
Source: helpers/update_coordinator.py:392
integration: ESPHome (documentation, issues)
First occurred: 10:14:47 (1 occurrences)
Last logged: 10:14:47
Error requesting ESPHome Dashboard data: Cannot connect to host 127.0.0.1:63290 ssl:default [Connect call failed (‘127.0.0.1’, 63290)]
Under the supervisor log I see a number of github errors that seem to indicate the there’s a problem accessing github (see attached)
If i open the Terminal i can run the same git commands without any issues.
I’ve done a lot of searching but can’t find anything that describes similar problems, or anywhere that has any solutions to these problems ? I’m now at a bit of a loss :frowning_with_open_mouth:
Can anyone give me any pointers … is there some diagnostics that i’m missing ? Anyone seen anything similar or have any suggestions ?
Log Extract:
2025-01-02 04:14:30.503 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-01-02 04:14:30.503 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-01-02 04:14:30.504 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-01-02 04:14:30.504 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-01-02 04:14:30.545 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-01-02 04:14:30.545 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-01-02 04:14:30.552 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-01-02 04:14:30.553 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-01-02 04:14:30.553 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-01-02 04:14:30.553 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-01-02 04:14:30.553 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-01-02 04:14:30.553 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-01-02 04:14:30.554 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-01-02 04:14:30.692 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-02 04:14:30.692 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-01-02 04:14:30.693 INFO (MainThread) [supervisor.resolution.fixups.store_execute_reset] Reset corrupt Store: d5369777
2025-01-02 04:14:30.696 ERROR (MainThread) [supervisor.utils] Can't remove folder /data/addons/git/d5369777: find: ‘/data/addons/git/d5369777’: No such file or directory
2025-01-02 04:14:30.697 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/music-assistant/home-assistant-addon repository
2025-01-02 04:14:30.767 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/music-assistant/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/music-assistant/home-assistant-addon /data/addons/git/d5369777
  stderr: 'Cloning into '/data/addons/git/d5369777'...
fatal: unable to access 'https://github.com/music-assistant/home-assistant-addon/': Could not resolve host: github.com
2025-01-02 04:14:30.767 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-01-02 04:14:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:14:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:14:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:16:29.725 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-01-02 04:16:36.096 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/home-assistant/addons
2025-01-02 04:16:36.099 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/britkat1980/giv_tcp repository
2025-01-02 04:16:38.128 ERROR (MainThread) [supervisor.store.git] Can't update https://github.com/britkat1980/giv_tcp repo: Cmd('git') failed due to: exit code(128)
  cmdline: git fetch -v --update-shallow --depth=1 -- origin
  stderr: 'fatal: unable to access 'https://github.com/britkat1980/giv_tcp/': Could not resolve host: github.com'.
2025-01-02 04:16:38.129 ERROR (MainThread) [supervisor.store] Could not reload repository a6a2857d due to StoreGitError()
2025-01-02 04:16:38.156 INFO (MainThread) [supervisor.store] Loading add-ons from store: 1 all - 0 new - 0 remove
2025-01-02 04:19:41.977 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:19:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:19:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:24:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:24:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:24:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:29:41.981 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:29:41.984 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:29:41.984 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:34:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:34:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:34:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:39:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:39:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:39:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:44:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:44:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:44:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:46:29.876 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-01-02 04:49:41.979 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:49:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:49:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:54:41.981 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:54:41.981 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:54:41.981 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:59:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:59:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 04:59:41.978 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:04:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:04:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:04:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:09:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'HOSTIP' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:09:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_CHARGE_RATE' does not exist in the schema for GivTCP (a6a2857d_givtcp)
2025-01-02 05:09:41.980 WARNING (MainThread) [supervisor.addons.options] Option 'PALM_BATT_CAPACITY' does not exist in the schema for GivTCP (a6a2857d_givtcp)
System Info
version | core-2024.12.5
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.0
os_name | Linux
os_version | 6.6.66-haos
arch | x86_64
timezone | Europe/London
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 5000
Installed Version | 2.0.1
Stage | running
Available Repositories | 1498
Downloaded Repositories | 5
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 14.1
update_channel | stable
supervisor_version | supervisor-2024.12.0
agent_version | 1.6.0
docker_version | 27.2.0
disk_total | 30.8 GB
disk_used | 19.4 GB
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization | vmware
board | ova
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.8.0), Samba share (12.3.2), Terminal & SSH (9.16.0), Mosquitto broker (6.4.1), GivTCP (2.4.9), Matter Server (6.6.1)
</details>
<details><summary>Dashboards</summary>
dashboards | 7
resources | 3
views | 5
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 12 December 2024 at 08:14
current_recorder_run | 21 December 2024 at 09:22
estimated_db_size | 843.24 MiB
database_engine | sqlite
database_version | 3.45.3
</details>
I have the same problem.
Addons reported as removed.
There seems to be a problem with my add on store.
The community store began working when i added the url again, but not the official. Then I get a “already added” message.
When git clearly can resolve the community url it should rule out a dns problem.
I also have the same problem. I have tried the following (as suggested in other threads/searches):
  • Changed the DNS settings to Google (8.8.8.8 and 8.8.4.4) and Cloudflare (1.1.1.1)
  • Updated HAOS multiple times (problem started back in late November)
  • Updated HA multiple times
  • Rebooted my RPI5 multiple times
  • Attempted to add the add on store URL again (rejected as previous posters)
Since I cannot install the SSH add on, I cannot force any updates within the HA container as recommended by others. I also do not have the ability to adjust the MTU size (working on the default installation size)
Other observations are:
  • No problem with updates of HA or HAOS
  • Weather service (yr.no) updates without problem
  • No issues connecting to the HA locally or remotely
  • No other laptops, desktops or servers has any problems reaching GitHub.com through routers or firewalls
  • The add on store initially worked and I managed to install both Z-Wave JS UI and Mosquitto broker which are still working fine (except that they will not update)
Any suggestion where to look or anything else I can do. Experienced Linux admin so not much on the command line will intimidate me :wink:
My configuration is on an RPI5 with POE/HD Hat:
Core 2025.1.4 Supervisor 2024.12.3 Operating System 14.2 Frontend 20250109.2
