Add-ons all shown as not running after update
Hi all I am in need of some help please if anyone can.
I have reciently had to reinstall homeassistant from a backup, and also updated to the latest version.
Home Assistant 2023.2.1
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
I am running it on a Pi 4B 2gb with a 64gb ssd.
After the updates had completed I tried to open File editor, and it indicated it was not running, but on checking I found all of my add ons are shown not running (greyed out), although the logs show they are all actually running. I cant access any of them, ie; file editor, terminal, esp-home etc.
has anyone come across this problem. I cant update anything as it is all up to date, and otherwise seems to be running ok.
thanks Ken
Anything in your logs?
OK, just realised you already mentioned about logs…
Sorry for that.
Hi Edward
nothing in the main logs currently.
and all the add on logs look ok all green.
I am stummped.
Ken
I also tried uninstalling file editor and re installing it but it has made no difference.
What if you remove one of the add-ons and then install it again? Like the File editor should cause no harm when removed and reinstalled?
Or trying to install some new one? It also become grayed out?
You probably have tried a host reboot already, right?
No I havent done a host reboot, I will just try it now thanks.
Hi Edward
That worked, thankyou for your help. I had been just restarting homeassistant, I have the pi on a ups so it was on all the time.
regards Ken
Great to hear it worked!
I am having the same issue, rebooted and everything started working for couple of hours but then it went down again. Nothing is loading I can’t even access the terminal.
