Add-Ons does not show on Settings Menu
Hello - New to HA and working with a new HA Green with HAOS 17.0 through Google Chrome. Trying to get the basics set up but the Add-Ons option will not show up in the Settings Menu. I have enabled Advanced Mode under my user profile. I have re-started HA. I have re-booted and shut down the HA Green completely and restarted it. I have cleared my browser cache. I have tried using MS Edge as the browser.
edit: I am trying to get HACS installed. When I go to HACS.xyz and try to download HACS, I get this message. “Error loading addon: Addon cb646a50_get does not exist”
Any suggestions on what to try next?
Their are called “apps” now. Don’t ask me why :wink:
Thanks. I’m trying to add HACS. Nothing is working in APPs…
just click the link…
HACS is under Settings > Devices & Services > Integrations
Then type in hacs on the search line for Integrations
Thank you. I tried searching on the Devices and Servoices tab and got nothing.
Lower right in that panel click on “Add Integration” button, that will pop-up the search bar/box
I have the same issue.
Following the “MyLink” from this place:
https://www.hacs.xyz/docs/use/download/download/
Gives me the same error message in Home Assistant:
HACS doesn’t have Add-ons. HACS doesn’t have Apps.
HACS has Custom Integrations, Themes, Custom Templates, and a few other things.
Apps are here: Open your Home Assistant instance and show the app store.
But he wants to install HACS… so the easiest way according to the docs is via addons… and only then will he have it in integrations. :man_shrugging:
Yes the Apps store has an Add-on(App) to install HACS. HACS doesn’t have Add-ons(Apps).
Hi Ken, maybe you’ve already figured it out by now, but if not, here’s the solution: Since the new version 2026.2 of Home Assistant, add-ons are now called apps. HACS is one such add-on/app. The installation solutions described by the previous speakers are based on the installer link on the official HACS website, which no longer seems to work since the renaming.
Here is the solution (sorry, the screenshots are in German):
Oh WTF, why did they have to change this. Always confusing the shite outta this old man, thought I was trippin
I had problems with Zigbee2MQTT and I couldn`t find Addons anymore.
Thanks you, that I can find it in Apps.
How do I get Apps in Sidebar again?^
Ah, I found it.
Just put the Link http://homeassistant.local:8123/config/apps/installed as a new Dashboard to my sidebar :nerd_face:
Thanks for this - extremely helpful!
Thank you ! Extremely helpful
