I recently did a backup and restoration to a bigger SD card and change the Raspberry Pi ( same model) but after that everything works perfectly but Add-ons icons are not coming up for some.
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/tellstick/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/cec_scan/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/cec_scan/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/almond/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/almond/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/duckdns/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/duckdns/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/homematic/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/homematic/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/ssh/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/ssh/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/samba/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/samba/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/mosquitto/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/mosquitto/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/nginx_proxy/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/nginx_proxy/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/dnsmasq/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/dnsmasq/config.json from repository core
20-06-16 22:44:34 ERROR (MainThread) [supervisor.utils.json] Can't read json from /data/addons/core/zwave/config.json: Expecting value: line 1 column 1 (char 0)
20-06-16 22:44:34 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/zwave/config.json from repository core
