Add option to change refresh rate for FritzBoxTools
If you want to monitor the upload and download speed of your fritzBox, you only get an update every 30 seconds, which is really slow and won’t show any spikes. The update interval should be manually configurable.
There is a generic way to use custom update intervals see Common tasks - installation independent - Home Assistant
Has anyone ever got this working? I have tried the suggested way, but the power or voltage updates are still not updating any 10s that I tried to set.
The only thing which worked for me was switching the device on when it is on, which apparently triggers an update. This however isn’t practical, e.g. if I am using a Dect440 to switch a dect210. Oftentimes the off state is then not available in ha yet, so it sends another switch on, which cancels my manual switch off before…
restructuring everything such that the switch on automation is disabled if I press the 440 is very impractical.
What is the lower limit of updates the dect 200/210 achieve?
is there any chance that a Python_script can be used to get an update?
yeah … check how often the data are updated on the fritzbox web-ui itself - you’ll see, they are also only updated every 10s (or so), because the devices does send the data only in such interval
I ended up with a command line sensor using curl: curl -s “http://$IP/net/home_auto_query.lua?sid=$SID&command=EnergyStats_10&id=$_didx&useajax=1&xhr=1&t=nocache” this way the data updates just fine for all plugs. Interval is about 10-15s.
