I find the hass.io automations GUI quite helpful to quickly get an automation with a trigger and a single condition going, but I soon wanted to add two conditions or three 'OR’d together, but there is no magic button to do that I think
From further reading I see that I can hand craft the automations script with ‘condition: or’ , but that leads to needing even more knowledge on using correct syntax in there. While yes I’m slowly learning it, it will be a disappointment to other newbies like me too. So if that makes sense could a dev please keep that in mind if revision to that comes up…
In the meantime, great work dev team, I’m telling all my geek friends about HA !
Was trying to do this same thing today and realized it’s not possible from the UI. When I try to manually edit the automations.yaml file to set the condition to ‘or’ and view the automation from the web UI, it shows the following:
