I’m looking for a way to control what devices get notificiations. I have created input_booleans for all devices and my idea is to add or remove the device from a group and send the notifications to that group. Is it possible to create an automation that triggers on changes in input_boolean and add or removes from a group?
No. There is no way to change the home assistant configuration with an automation. A group definition is part of the configuration.
You could create a notification service for each recipient and choose which ones get used by implementing a service template dependant on your input booleans.
I see. I have never used service template before. This is the code i used in automations:
- service: notify.all_iphones
message: xxx xxxx xxxx
Can someone guide me how to split this into two different devices and check input_boolean?
Something like this:
configuration.yaml
notify:
- platform: group
services:
- service: mobile_app_iphone_1
- service: mobile_app_iphone_2
- service: mobile_app_ipad_1
- service: mobile_app_ipad_2
- platform: group
services:
automation:
- service_template: >
{% if is_state('input_boolean.your_input_boolean_here', 'on') %}
notify.all_iphones
{% else %}
notify.some_iphones
{% endif %}
message: "xxx xxxx xxxx"
Is it possible to do this without the groups. Like:
{% if is_state('input_boolean.iphone_1', 'on') %}
notify.iphone_1
{% if is_state('input_boolean.iphone_2', 'on') %}
notify.iphone_2
{% else %}
{% endif %}
Sure but you need to supply an ‘else’ case or it will generate errors if none of the input booleans are on.
notify.iphone_1
notify.iphone_2
{% else %}
### YOU NEED SOMETHING HERE ###
{% endif %}
Or you need to ensure that at lease one of the input booleans is on in the automation conditions.
condition:
- condition: or
conditions:
- condition: state
entity_id: input_boolean.iphone_1
state: 'on'
- condition: state
entity_id: input_boolean.iphone_2
state: 'on'
notify.iphone_1
notify.iphone_2
{% endif %}
Hey @backisen you might want to have a look at this post, it seems there is a group.set service:
