When adding devices / entities, I only have a problem with the VMBGP1 (Built 2221), which I cannot add in Home Assistant (with Sigmum).
I have already refreshed the Sigmum and made a scan via the local Velbus gateway. without result, the module is not hidden either.
the push button itself works normally and so does the programming in Velbuslink
Anyone have an idea what could be causing this?
Thank you
