Shelly.GetConfig : Look at “input:2” → xfreq
"ble": {
"enable": false,
"rpc": {
"enable": true
"observer": {
"enable": false
"cloud": {
"enable": true,
"server": "aaaaaaaaaa:6022/jrpc"
"input:0": {
"id": 0,
"name": null,
"type": "switch",
"enable": true,
"invert": false
"input:1": {
"id": 1,
"name": null,
"type": "switch",
"enable": true,
"invert": false
"input:2": {
"id": 2,
"name": "Flow",
"type": "count",
"enable": true,
"count_rep_thr": 100,
"freq_window": 1,
"freq_rep_thr": 10,
"xcounts": {
"expr": "x*1",
"unit": "L"
"xfreq": {
"expr": "x*0.9",
"unit": "L/min"
"mqtt": {
"enable": false,
"server": null,
"client_id": "shellyplusuni-aaaaaaaa",
"user": null,
"ssl_ca": null,
"topic_prefix": "shellyplusuni-aaaaaaaa",
"rpc_ntf": true,
"status_ntf": false,
"use_client_cert": false,
"enable_rpc": true,
"enable_control": true
"switch:0": {
"id": 0,
"name": null,
"in_mode": "follow",
"initial_state": "match_input",
"auto_on": false,
"auto_on_delay": 60,
"auto_off": false,
"auto_off_delay": 60
"switch:1": {
"id": 1,
"name": null,
"auto_on": false,
"auto_off": false,
"sys": {
"device": {
"name": null,
"mac": "aaaaaa",
"fw_id": "20240223-142029/1.2.2-g7c39781",
"discoverable": true,
"eco_mode": false
"location": {
"tz": "Europe/Paris",
"lat": 0,
"lon": 0
"debug": {
"level": 2,
"file_level": null,
"mqtt": {
"enable": false
"websocket": {
"enable": false
"udp": {
"addr": null
"ui_data": {
"rpc_udp": {
"dst_addr": null,
"listen_port": null
"sntp": {
"server": "time.google.com"
"cfg_rev": 29
"voltmeter:100": {
"id": 100,
"name": null,
"report_thr": 0.1,
"range": 0,
"xvoltage": {
"expr": null,
"unit": null
"wifi": {
"ap": {
"ssid": "ShellyPlusUni-aaaaaa",
"is_open": false,
"enable": false,
"range_extender": {
"enable": false
"sta": {
"ssid": "aaaa",
"is_open": false,
"enable": true,
"ipv4mode": "dhcp",
"ip": null,
"netmask": null,
"gw": null,
"nameserver": null
"sta1": {
"ssid": null,
"is_open": true,
"enable": false,
"ipv4mode": "dhcp",
"ip": null,
"netmask": null,
"gw": null,
"nameserver": null
"roam": {
"rssi_thr": -80,
"interval": 60
"ws": {
"enable": false,
"server": null,
"ssl_ca": "ca.pem"
