Add the ability to specify how many times a timer should run (default is repetitions: 1
In the following example, the timer is configured to run ten times. When started, it will run for a duration of 30 seconds, fire a timer.finished
event, then automatically restart itself (and repeat this behavior for a total of ten times).
timer:
test:
duration: '00:00:30'
repetitions: 10
All existing timer services continue to work as they currently do, providing start
, pause
, cancel
, and finish
The timer.start
service should be enhanced to support repetitions
as an optional parameter.
Attribute Optional Description
entity_id no Name of the entity to take action, e.g., timer.timer0.
duration yes Duration in seconds or 00:00:00 until the timer finishes.
repetitions yes Number of times the timer should run (default is 1).
This request permits a timer to trigger an automation for a given number of repetitions without the automation having to manage the timer’s repetition count (using a counter value). The optional repetitions
parameter allows the timer to manage itself.
Applications:
In the following examples, an automation can dynamically set a timer’s duration
and repetitions
and start/pause/cancel/finish the timer there by providing complete control over the timer’s operation.
Send a notification, play an announcement, or toggle a light X times every Y seconds (
repetitions: X
,duration: Y
Ramp a light’s brightness or a media_player’s volume in 5 steps of 10% every 3 seconds (
repetitions: 5
,duration: 3
