egrootoonk
(Edwin Grootoonk)
March 26, 2019, 10:30pm
1
I have a problem setting up an rflink doorbell.
The doorbeld push-button sends a “on” signal, but when I look at the log file, the doorbell sends a “ALLON”
what I did was:
sensors.yaml
- platform: rflink
devices:
newkaku_00d4407a_0:
sensor_type: command
binary_sensor.yaml
sensors:
deurbel_on:
friendly_name: "Deurbel gaat"
delay_off:
seconds: 2
value_template: >-
{{ is_state('sensor.deurbel', "ALLON") }}
What am I doing wrong here.
Logfile
``` 2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] received data: 2
2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] received data: 0;CF;NewKaku;ID=00d4407a
2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] received data: ;SWITCH=0;CMD=ALLON;
2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] got packet: 20;CF;NewKaku;ID=00d4407a;SWITCH=0;CMD=ALLON;
2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '00d4407a', 'switch': '0', 'command': 'allon'}
2019-03-26 23:13:28 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_00d4407a_0', 'command': 'allon'} ```
123
(Taras)
March 27, 2019, 2:36pm
2
Go to the States page and find sensor.deurbel
Check if its state is allon
or ALLON
(or simply on
If it’s allon
(or on
) then change the value_template
accordingly.
value_template: >-
{{ is_state('sensor.deurbel', "allon") }} # or "on" depending on what the States page shows
egrootoonk
(Edwin Grootoonk)
March 28, 2019, 4:15pm
3
I checked the logs it sends ALLON when pressed.
2019-03-28 13:38:05 DEBUG (MainThread) [rflink.protocol] got packet: 20;0E;NewKaku;ID=00d4407a;SWITCH=0;CMD=ALLON;
I see in the frond-end that the sensor.deurbel is activated, but I can’t get the binary sensor triggerd.
javicalle
(javicalle)
March 28, 2019, 7:21pm
4
It’s not posible to configure it with a RFLink binary sensor ?
binary_sensor:
- platform: rflink
devices:
newkaku_00d4407a_0: {}
Anyway, I think the doorbell state will be on
. You can see it at States page (http://hassio.local:8123/dev-state or what you have configured in your installation), scroll to your sensor.deurbel
, the second column will show the doorbell state. It will be probably on
/off
123
(Taras)
March 28, 2019, 7:25pm
5
That’s exactly what I asked … but received a reply about the state sent by rflink (“ALLON”).
@egrootoonk
“ALLON” is the command state sent by rflink. sensor.deurbel
will have Home Assistant’s valid states for a binary sensor (on
/off
Change the value_template
value_template: >-
{{ is_state('sensor.deurbel', 'on') }}
@egrootoonk : How did you manage to add the doorbell as a sensor? For me it only works if I make it a switch. And then once it’s pressed it stays on forever
With your configuration above, the sensor isn’t triggered for me and stays ‘unknown’.
egrootoonk
(Edwin Grootoonk)
September 16, 2019, 8:00am
7
in binary_sensor.yaml I created the sensor using a template with delay_off function.
My Doorbell sends an “allon” when pressed. (so not an “on” signal).
sensors:
deurbel:
friendly_name: "Deurbel"
delay_off:
seconds: 2
value_template: >-
I could not get this to work with a binary_sensor so i added it as an switch that i turn off with automation:
switch:
- platform: rflink
devices:
newkaku_007fb4c6_0:
fire_event: true
automation:
- alias: Doorbell
- platform: state
entity_id: switch.doorbell
to: 'on'
- service: notify.notify_pushover
data_template:
title: "Doorbell"
message: "Someone is at the door!"
- service: switch.turn_off
