Add sensor to Fritz!box integration for status of External acces. (wireguard VPN)
Hi, Fritz!box has a WireGuard feature for a Tunnel to your home network. When a device connects by using the WireGuard app on smartphones or an other device you can see it in the Fritz!box. External Access turns on.
Can we get a sensor in HA for this? I’d like to create a notification automation to keep track of the status and be notified when the tunnel is active.
i think the AVM FRITZ!Box Tools Integration does not provide these details. However you could use AppDaemon or Pyscript to update a sensor.
Please be aware that the login info for your FritzBox is needed for that, which might introduce a security risk. I would definitely recommend to create a separate user inside your fritzbox (System > Fritz!Box Users) for that use case.
The following script could be a starting point, however it currently lacks the final implementation to create/update a HA sensor.
#!/usr/bin/env python3
FRITZ!OS WebGUI Login
Get a sid (session ID) via PBKDF2 based challenge response algorithm.
Fallback to MD5 if FRITZ!OS has no PBKDF2 support.
AVM 2020-09-25
edited on 2024-10-14 to obtain vpn info and send it to HA
import sys
import json
import hashlib
import time
import urllib.request
import urllib.parse
import xml.etree.ElementTree as ET
LOGIN_SID_ROUTE = "/login_sid.lua?version=2"
def get_fritzbox_data(url:str, sid:str) -> dict[str, any]:
    # Define the URL
    url = f'{url}/data.lua'
    # Define the headers
    headers = {
        'Accept': '*/*',
        'Accept-Language': 'de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7',
        'Connection': 'keep-alive',
        'Content-Type': 'application/x-www-form-urlencoded',
        'Origin': f'http://{url}',
        'Referer': f'http://{url}/',
        'User-Agent': 'Mozilla/5.0 (iPhone; CPU iPhone OS 16_6 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.6 Mobile/15E148 Safari/604.1'
    # Define the data
    data = {
        'xhr': '1',
        'sid': sid,
        'lang': 'de',
        'page': 'overview',
        'xhrId': 'all',
        'useajax': '1',
        'no_sidrenew': ''
    data_encoded = urllib.parse.urlencode(data).encode('utf-8')
    req = urllib.request.Request(url, data=data_encoded, headers=headers)
    response = urllib.request.urlopen(req)
    response_data = response.read().decode('utf-8')
    return(json.loads(response_data))
class LoginState:
    def __init__(self, challenge: str, blocktime: int):
        self.challenge = challenge
        self.blocktime = blocktime
        self.is_pbkdf2 = challenge.startswith("2$")
def get_sid(box_url: str, username: str, password: str) -> str:
    """ Get a sid by solving the PBKDF2 (or MD5) challenge-response
    process.
    try:
        state = get_login_state(box_url)
    except Exception as ex:
        raise Exception("failed to get challenge") from ex
    if state.is_pbkdf2:
        print("PBKDF2 supported")
        challenge_response = calculate_pbkdf2_response(state.challenge, password)
    else:
        print("Falling back to MD5")
        challenge_response = calculate_md5_response(state.challenge, password)
    if state.blocktime > 0:
        print(f"Waiting for {state.blocktime} seconds...")
        time.sleep(state.blocktime)
    try:
        sid = send_response(box_url, username, challenge_response)
        raise Exception("failed to login") from ex
    if sid == "0000000000000000":
        raise Exception("wrong username or password")
    return sid
def get_login_state(box_url: str) -> LoginState:
    """ Get login state from FRITZ!Box using login_sid.lua?version=2 """
    url = box_url + LOGIN_SID_ROUTE
    http_response = urllib.request.urlopen(url)
    xml = ET.fromstring(http_response.read())
    # print(f"xml: {xml}")
    challenge = xml.find("Challenge").text
    blocktime = int(xml.find("BlockTime").text)
    return LoginState(challenge, blocktime)
def calculate_pbkdf2_response(challenge: str, password: str) -> str:
    """ Calculate the response for a given challenge via PBKDF2 """
    challenge_parts = challenge.split("$")
    # Extract all necessary values encoded into the challenge
    iter1 = int(challenge_parts[1])
    salt1 = bytes.fromhex(challenge_parts[2])
    iter2 = int(challenge_parts[3])
    salt2 = bytes.fromhex(challenge_parts[4])
    # Hash twice, once with static salt...
    hash1 = hashlib.pbkdf2_hmac("sha256", password.encode(), salt1, iter1)
    # Once with dynamic salt.
    hash2 = hashlib.pbkdf2_hmac("sha256", hash1, salt2, iter2)
    return f"{challenge_parts[4]}${hash2.hex()}"
def calculate_md5_response(challenge: str, password: str) -> str:
    """ Calculate the response for a challenge using legacy MD5 """
    response = challenge + "-" + password
    # the legacy response needs utf_16_le encoding
    response = response.encode("utf_16_le")
    md5_sum = hashlib.md5()
    md5_sum.update(response)
    response = challenge + "-" + md5_sum.hexdigest()
    return response
def send_response(box_url: str, username: str, challenge_response: str) -> str:
    """ Send the response and return the parsed sid. raises an Exception on error """
    # Build response params
    post_data_dict = {"username": username, "response": challenge_response}
    post_data = urllib.parse.urlencode(post_data_dict).encode()
    headers = {"Content-Type": "application/x-www-form-urlencoded"}
    # Send response
    http_request = urllib.request.Request(url, post_data, headers)
    http_response = urllib.request.urlopen(http_request)
    # Parse SID from resulting XML.
    return xml.find("SID").text
def logout(box_url: str, sid: str) -> bool:
    """ Send the logout requests to deactiate the session-id immediatly """
    post_data_dict = {"logout": "", "sid": sid}
    # Send response
    return xml.find("SID").text == '0000000000000000' # will return True if logged out successfully
def main():
    url = "http://fritz.box" # the url of your router, can be an ip-address as well
    username = "MYUSERNAME" # the username; in the FritzBox Admin Panel go to: "System" > "Fritz!Box-Users". The username usually starts with "fritz..."
    password = "MYPASSWORD" # the password to log into the admin console; usually written somewhere on the back of your fritzbox
    # 1) Log into the fritzbox
    sid = get_sid(url, username, password)
    print(f"Successful login for user: {username}")
    # 2) Access all your current data as json
    data = get_fritzbox_data(url=url, sid=sid)
    # 3) Parse the relevant vpn information
    vpn_status = {vpn['name']:vpn['led'] for vpn in data['data']['vpn']['elements']}
    # vpn_status is a dict with all vpn connections, e.g.: {"my_wireguard_connection1": "1", "my_wireguard_connection2": "0" , ...}
    # print all vpn connection and their status
    for k,v in vpn_status.items():
        print(f"VPN Connection with name {k} is {'being used' if(v=='1') else 'not being used'} at the moment.")
    # 4) Logout / deactive the session-id
    logout_state = logout(box_url=url, sid=sid)
    if(logout_state):
        print("You are logged out now!")
    # 5) Set the current vpn status
        #### TODO ###
        #### set the sensor value using AppDaemon here ###
if __name__ == "__main__":
    main()
Hi @Zwijgplicht
could you please provide some screenshots of the information you want to see in HA? A first search about vpns through the available apis only points to the X_AVM-DE_AppSetup service api. But maybe your remote device will be recognized by the mesh topology data which are already used inside the AVM Fritz!Tools integration :thinking:
i actually figured out a much simpler way than my first described one (no coding needed):
  1. Find the IP-Address of your Wireguard VPN Connection → see the network tab of your fritzbox router (each Wireguard connection should point to a distinct IP-Adress outside of your DHCP range, e.g. xxx.xxx.xxx.200)
  2. Install / Activate the “Ping” Integration of homeassistant (see here)
  3. Add a new device using the installed ping integrations (Go to Settings → Integrations → Ping: add new device. Use the IP-Address from Step 1)
  4. Finished. You can now use the created device as a device tracker
I initially created a ping sensor as well. It works only when the phone is on screen. When the screen is off, the ping sensor goes off, but the VPN status in the router remains active!!
@mib1185
Any chance you are going to add VPN status binary sensors to the Fritz box integration?
as mentioned in Add sensor to Fritz!box integration for status of External acces. (wireguard VPN) - #3 by mib1185 there is no API endpoint about VPN states available. Further there are open questions, about which data are wanted to be shown? Maybe it is already part of the mesh data, those available as a device tracker entity?
Just published a FritzBox VPN HACS integration, which does what you might need:
https://github.com/rosch100/fritzbox-vpn
