I would like to add some sensor values (windforce and windspeed) from buienradar to the weather-forecast card, Cannot find how to do that.
Is it possible or is there an alternative ?
You want the weather template. Here is a copy of what I use with my own weather station.
weather:
name: My Local Weather
condition_template: "{{ states('sensor.wf_weather') }}"
temperature_template: "{{ states('sensor.wf_temperature') | float}}"
humidity_template: "{{ states('sensor.wf_humidity')| int }}"
pressure_template: "{{ states('sensor.wf_sea_level_pressure')| float }}"
wind_speed_template: "{{ ( states('sensor.wf_wind_speed_avg') | float * 18 / 5 ) | round(2) }}"
wind_bearing_template: "{{ states('sensor.wf_wind_bearing_avg')| int }}"
visibility_template: "{{ states('sensor.wf_visibility')| float }}"
forecast_template: "{{ state_attr('sensor.wf_weather', 'hourly_forecast') }}"
