opened 05:44AM - 19 Dec 22 UTC
closed 12:09AM - 20 Dec 22 UTC
integration: google
### The problem
Previously I had a script that ran the following to reset the c…alendar prompting an immediate sync with Google.
alias: Reload Calendars
sequence:
- service: homeassistant.reload_config_entry
data: {}
entity_id: calendar.schedule
mode: single
icon: mdi:calendar-today
It was working fine for months, but now the calendar integration is fixed again I decided to reinstate my google_calendar.yaml so I can move all my schedule entries back into a single calendar with HA showing each type of event split into each’s own entity/calendar.
Since reinstating the file, I now get an error pop-up when running the command either from the script or directly in Developer Tools | Services.
If I go to Settings | Devices and manually reload the Google Calendar integration there it works fine.
### What version of Home Assistant Core has the issue?
2022.12.7
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Google Calendar
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/google/
### Diagnostics information
[home-assistant_google_2022-12-19T05-40-17.903Z.log](https://github.com/home-assistant/core/files/10256244/home-assistant_google_2022-12-19T05-40-17.903Z.log)
### Example YAML snippet
```yaml
sequence:
data: {}
mode: single
### Anything in the logs that might be useful for us?
```txt
2022-12-19 05:31:49.979 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546983628272] Error handling message: Unknown error (unknown_error) from 192.168.0.10 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 646, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1745, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1782, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 748, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 262, in async_handle_reload_config_entry
raise ValueError("There were no matching config entries to reload")
ValueError: There were no matching config entries to reload
### Additional information
The error seems specific to the use of the google_calendar.yaml file
I tried with a few other calendars (same account), but got the same error each time
